Nintendo Wii U GamePad Outer Case Replacement
  1. Nintendo Wii U GamePad Outer Case Replacement, Battery: step 1, image 1 of 2 Nintendo Wii U GamePad Outer Case Replacement, Battery: step 1, image 2 of 2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Nintendo Wii U GamePad Outer Case Replacement: step 2, image 1 of 3 Nintendo Wii U GamePad Outer Case Replacement: step 2, image 2 of 3 Nintendo Wii U GamePad Outer Case Replacement: step 2, image 3 of 3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Nintendo Wii U GamePad Outer Case Replacement, GamePad Outer Case: step 3, image 1 of 3 Nintendo Wii U GamePad Outer Case Replacement, GamePad Outer Case: step 3, image 2 of 3 Nintendo Wii U GamePad Outer Case Replacement, GamePad Outer Case: step 3, image 3 of 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Nintendo Wii U GamePad Outer Case Replacement: step 4, image 1 of 2 Nintendo Wii U GamePad Outer Case Replacement: step 4, image 2 of 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
Kim Arre
4,918 Reputation
8 Guides authored
Cal Poly, Team 17-20, Forte Winter 2013 Member of Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Members
39 Guides authored
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 113
All Time: 14,767
