WRS315SDHW Icemaker Auger Assembly Replacement
  1. WRS315SDHW Icemaker Auger Assembly Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Icemaker Auger Assembly Replacement, Open the doors: step 2, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Open the doors: step 2, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Icemaker Auger Assembly Replacement, Remove the icemaker tray: step 3, image 1 of 2 WRS315SDHW Icemaker Auger Assembly Replacement, Remove the icemaker tray: step 3, image 2 of 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Icemaker Auger Assembly Replacement, Unfasten the icemaker assembly: step 4, image 1 of 2 WRS315SDHW Icemaker Auger Assembly Replacement, Unfasten the icemaker assembly: step 4, image 2 of 2
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: step 5, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: step 5, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: step 5, image 3 of 3
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: step 6, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: step 6, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: step 6, image 3 of 3
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Icemaker Auger Assembly Replacement, Remove the icemaker assembly: step 7, image 1 of 1
    • Remove the icemaker assembly.
  8. WRS315SDHW Icemaker Auger Assembly Replacement, Unfasten the icemaker auger assembly: step 8, image 1 of 1
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: step 9, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: step 9, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: step 9, image 3 of 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: step 10, image 1 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: step 10, image 2 of 3 WRS315SDHW Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: step 10, image 3 of 3
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Icemaker Auger Assembly Replacement, Remove the icemaker auger assembly: step 11, image 1 of 1
    • Remove the icemaker auger assembly.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,945 Reputation
89 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 220
