WRS315SDHW Door Sensor Replacement
  1. WRS315SDHW Door Sensor Replacement, Open the doors: step 1, image 1 of 3 WRS315SDHW Door Sensor Replacement, Open the doors: step 1, image 2 of 3 WRS315SDHW Door Sensor Replacement, Open the doors: step 1, image 3 of 3
    • Depending on your repair, open one or both doors.
  2. WRS315SDHW Door Sensor Replacement, Unclip the door sensor: step 2, image 1 of 3 WRS315SDHW Door Sensor Replacement, Unclip the door sensor: step 2, image 2 of 3 WRS315SDHW Door Sensor Replacement, Unclip the door sensor: step 2, image 3 of 3
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. WRS315SDHW Door Sensor Replacement: step 3, image 1 of 2 WRS315SDHW Door Sensor Replacement: step 3, image 2 of 2
    • Pull the door sensor through the chassis enough to access its connector.
    • Disconnect the spade connector attached to the door sensor.
    • Remove the door sensor.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,945 Reputation
89 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 148
