Vornado Duo Power Button Replacement
  1. Vornado Duo Power Button Replacement, Power Button: step 1, image 1 of 2 Vornado Duo Power Button Replacement, Power Button: step 1, image 2 of 2
    • Start off by using a Philips #2 screwdriver to remove all 8 10mm exterior screws on the rear of the device.
  2. Vornado Duo Power Button Replacement: step 2, image 1 of 3 Vornado Duo Power Button Replacement: step 2, image 2 of 3 Vornado Duo Power Button Replacement: step 2, image 3 of 3
    • After screws have been removed, open fan up. Inside remove the black and silver directional fins.
  3. Vornado Duo Power Button Replacement: step 3, image 1 of 3 Vornado Duo Power Button Replacement: step 3, image 2 of 3 Vornado Duo Power Button Replacement: step 3, image 3 of 3
    • Remove the black 5mm screw inside of the fan blade cylinder.
  4. Vornado Duo Power Button Replacement: step 4, image 1 of 1
    • Find and locate the 10 mm screws on both sides of the circuit board enclosure. Remove both screws.
  5. Vornado Duo Power Button Replacement: step 5, image 1 of 2 Vornado Duo Power Button Replacement: step 5, image 2 of 2
    • Take out the fan cylinder and the circuit board enclosure.
  6. Vornado Duo Power Button Replacement: step 6, image 1 of 3 Vornado Duo Power Button Replacement: step 6, image 2 of 3 Vornado Duo Power Button Replacement: step 6, image 3 of 3
    • Look inside the frontal shell of the fan and locate power button.
    • Remove by gently pulling button off notch and replace with new power button.
Kyle Devoe
134 Reputation
1 Guide authored
USF Tampa, Team S1-G1, Nance Fall 2017 Member of USF Tampa, Team S1-G1, Nance Fall 2017
USFT-NANCE-F17S1G1
3 Members
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 802
