Voluas VL001 Portion Switch Replacement
    1. Voluas VL001 Portion Switch Replacement, Storage Tank: step 1, image 1 of 3 Voluas VL001 Portion Switch Replacement, Storage Tank: step 1, image 2 of 3 Voluas VL001 Portion Switch Replacement, Storage Tank: step 1, image 3 of 3
      • Remove the lid to the storage tank by using the latch and lifting off.
      • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
      Ask FixBot
    1. Voluas VL001 Portion Switch Replacement, Battery: step 2, image 1 of 3 Voluas VL001 Portion Switch Replacement, Battery: step 2, image 2 of 3 Voluas VL001 Portion Switch Replacement, Battery: step 2, image 3 of 3
      • Place your pet feeder upside down.
      • Squeeze the lock and remove the battery cover.
      • Remove the three 1.5V D alkaline batteries.
      Ask FixBot
    1. Voluas VL001 Portion Switch Replacement, Housing: step 3, image 1 of 3 Voluas VL001 Portion Switch Replacement, Housing: step 3, image 2 of 3 Voluas VL001 Portion Switch Replacement, Housing: step 3, image 3 of 3
      • Insert a metal spudger under the adhesive part of each rubber foot.
      • Pry the foot off.
      Ask FixBot
    2. Voluas VL001 Portion Switch Replacement: step 4, image 1 of 2 Voluas VL001 Portion Switch Replacement: step 4, image 2 of 2
      • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
      • These holes were previously covered by the rubber feet.
      • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
      Ask FixBot
    3. Voluas VL001 Portion Switch Replacement: step 5, image 1 of 1
      • Turn the device over so it is oriented right-side up.
      • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
      Ask FixBot
    1. Voluas VL001 Portion Switch Replacement, Portion Switch: step 6, image 1 of 3 Voluas VL001 Portion Switch Replacement, Portion Switch: step 6, image 2 of 3 Voluas VL001 Portion Switch Replacement, Portion Switch: step 6, image 3 of 3
      • Remove the two 11.1 mm screws that secure the switch to the device using a Phillips #2 screwdriver.
      Ask FixBot
    2. Voluas VL001 Portion Switch Replacement: step 7, image 1 of 2 Voluas VL001 Portion Switch Replacement: step 7, image 2 of 2
      • Using your wire strippers/pliers, cut the three wires that are connected to the switch.
      Ask FixBot
    3. Voluas VL001 Portion Switch Replacement: step 8, image 1 of 3 Voluas VL001 Portion Switch Replacement: step 8, image 2 of 3 Voluas VL001 Portion Switch Replacement: step 8, image 3 of 3
      • Using your wire strippers/pliers, gently crimp the plastic insulation on the wire. Do this several times around the wire to make sure that you can pull it off.
      • Because the wire is so thin, it can be easy to accidentally cut all the way through the wire on this step. Take care to only cut through the insulation.
      • You will want to see a score line in the insulation all around the wire like this.
      • Pull the end of the insulation off, exposing the wire.
      Ask FixBot
    4. Voluas VL001 Portion Switch Replacement: step 9, image 1 of 2 Voluas VL001 Portion Switch Replacement: step 9, image 2 of 2
      • Put the exposed wire on the solder patch, making sure it has good contact with the metal.
      • Solder the wire on to the solder patch.
      • Repeat steps 8 and 9 for the other two wires.
      Ask FixBot
Jade Thomson
699 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 57
All Time: 372
