Valve Index Controller Left Hand Strap Replacement
  1. Valve Index Controller Left Hand Strap Replacement, Remove the elastic band: step 1, image 1 of 3 Valve Index Controller Left Hand Strap Replacement, Remove the elastic band: step 1, image 2 of 3 Valve Index Controller Left Hand Strap Replacement, Remove the elastic band: step 1, image 3 of 3
    • Press and hold the elastic band adjustment button.
    • Slide the elastic band out of the controller.
    • During reassembly, pinch the elastic band near the tip of the loop and slide it into the controller.
  2. Valve Index Controller Left Hand Strap Replacement, Insert an opening pick: step 2, image 1 of 3 Valve Index Controller Left Hand Strap Replacement, Insert an opening pick: step 2, image 2 of 3 Valve Index Controller Left Hand Strap Replacement, Insert an opening pick: step 2, image 3 of 3
    • Insert an opening pick under the round plastic cover next to the A and B buttons.
    • Do not insert the opening pick more than 5 mm (0.2 in) into the controller, or you may tear the touchpad ribbon cable.
    • Slide the opening pick around the top of the controller until all three plastic clips are disengaged.
  3. Valve Index Controller Left Hand Strap Replacement, Open the controller: step 3, image 1 of 2 Valve Index Controller Left Hand Strap Replacement, Open the controller: step 3, image 2 of 2
    • Carefully open the top of the controller to access the screws inside.
    • Be careful not to strain or tear the ribbon cable connected to the touchpad.
  4. Valve Index Controller Left Hand Strap Replacement, Unscrew the adjustment strap: step 4, image 1 of 2 Valve Index Controller Left Hand Strap Replacement, Unscrew the adjustment strap: step 4, image 2 of 2
    • Use a T5 Torx screwdriver to remove the two 6.1 mm screws securing the adjustment strap to the controller.
    • Once the adjustment strap is unscrewed, the spring underneath may fall out.
    • Make sure the spring is installed during reassembly, or the ratcheted adjustment mechanism will not work properly.
  5. Valve Index Controller Left Hand Strap Replacement, Remove the adjustment strap: step 5, image 1 of 2 Valve Index Controller Left Hand Strap Replacement, Remove the adjustment strap: step 5, image 2 of 2
    • Slide the adjustment strap out from the controller to remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
3 other people completed this guide.
Sam Omiotek
72,896 Reputation
288 Guides authored
3 Comments
Doesn't explain how to put it back together with the spring which is conveniently missing from the photos.
Draylynn - Reply
I'm several months late, but just in case I figured I'd toss a reply just in case you were interested in the imgur guide I made to help out anyone else struggling with this. It's posted as a separate comment on this post. Hope your repair went well otherwise!
VaporStrike -
I appreciate the guide, but as someone noted above, you are seriously lacking in the spring instructions, which might be the most important part of this assembly. However, I managed to find a way to get the spring seated back in on my own, and so for any other unfortunates stumbling onto this guide, I made my own crappy Imgur gallery guide for re-seating the spring. Each image has a small paragraph beneath it explaining the steps to take. I hope it manages to help anyone else struggling to swap out a strap.
(NOTE: Images were made for Right hand controller, simply mirror for Left hand.)
https://imgur.com/gallery/RQYtS5e
VaporStrike - Reply
Past 24 Hours: 18
Past 7 Days: 55
Past 30 Days: 272
All Time: 10,653
