VTech Learning Tunes Karaoke Mode Selector Replacement
  1. VTech Learning Tunes Karaoke Mode Selector Replacement, Mode Selector: step 1, image 1 of 1
    • To remove the battery door, loosen the 4mm Flathead screw.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Mode Selector Replacement: step 2, image 1 of 2 VTech Learning Tunes Karaoke Mode Selector Replacement: step 2, image 2 of 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Mode Selector Replacement: step 3, image 1 of 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Mode Selector Replacement: step 4, image 1 of 2 VTech Learning Tunes Karaoke Mode Selector Replacement: step 4, image 2 of 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Mode Selector Replacement: step 5, image 1 of 1
    • Remove the two 7.9 mm Phillips #1 mode switch board screws.
  6. VTech Learning Tunes Karaoke Mode Selector Replacement: step 6, image 1 of 2 VTech Learning Tunes Karaoke Mode Selector Replacement: step 6, image 2 of 2
    • Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
  7. VTech Learning Tunes Karaoke Mode Selector Replacement: step 7, image 1 of 2 VTech Learning Tunes Karaoke Mode Selector Replacement: step 7, image 2 of 2
    • Using a Philips #1 screwdriver, remove the two 5.6 mm screws on the switch.
    • Once the screws have been removed, you can easily remove the mode switch.
Adam Chaberek
137 Reputation
1 Guide authored
USF Tampa, Team 7-2, Cheng Spring 2016 Member of USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Members
10 Guides authored
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 13
All Time: 285
