Introduction
Can't switch modes between songs? This guide will show you how to replace a faulty mode selector.
Gently pull up on the rear panel.
Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
Using a Philips PH1 screwdriver, remove the two 5.6 mm screws on the switch.
Once the screws have been removed, you can easily remove the mode switch.
