VTech InnoTab 2 Headphone Jack Replacement
    1. VTech InnoTab 2 Headphone Jack Replacement, Battery: step 1, image 1 of 3 VTech InnoTab 2 Headphone Jack Replacement, Battery: step 1, image 2 of 3 VTech InnoTab 2 Headphone Jack Replacement, Battery: step 1, image 3 of 3
      • Apply slight pressure and slide the button above the battery cabinet to the right to open.
      • Remove battery cabinet cover by sliding away from the center of device.
      • This device requires 4AA batteries to function without the AC adaptor.
      Ask FixBot
    1. VTech InnoTab 2 Headphone Jack Replacement, Back Panel: step 2, image 1 of 3 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: step 2, image 2 of 3 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: step 2, image 3 of 3
      • Remove all nine plastic caps from the back of the device using the plastic opening tool.
      • These covers are made of hard plastic so they may be difficult to remove.
      Ask FixBot
    2. VTech InnoTab 2 Headphone Jack Replacement: step 3, image 1 of 3 VTech InnoTab 2 Headphone Jack Replacement: step 3, image 2 of 3 VTech InnoTab 2 Headphone Jack Replacement: step 3, image 3 of 3
      • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
      • Be careful not to apply excessive force.
      • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
      Ask FixBot
    3. VTech InnoTab 2 Headphone Jack Replacement: step 4, image 1 of 2 VTech InnoTab 2 Headphone Jack Replacement: step 4, image 2 of 2
      • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
      • Do not use excessive force while removing the screws to prevent damaging the plastic case.
      Ask FixBot
    4. VTech InnoTab 2 Headphone Jack Replacement: step 5, image 1 of 2 VTech InnoTab 2 Headphone Jack Replacement: step 5, image 2 of 2
      • Using the plastic opening tool, detach the back plate from the front piece.
      • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
      • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
      Ask FixBot
    1. VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: step 6, image 1 of 3 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: step 6, image 2 of 3 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: step 6, image 3 of 3
      • Remove the two 7 mm screws from the left bumper of the device using a JO screwdriver.
      • Be careful not to pull to hard when removing the bumper to avoid damage to the circuit.
      Ask FixBot
    2. VTech InnoTab 2 Headphone Jack Replacement: step 7, image 1 of 3 VTech InnoTab 2 Headphone Jack Replacement: step 7, image 2 of 3 VTech InnoTab 2 Headphone Jack Replacement: step 7, image 3 of 3
      • Use your fingers to gently remove the headphone jack.
      • De-solder the points shown to fully remove the headphone jack from the motherboard.
      • A soldering guide offered by IFIXIT can be found here Soldering Skills
      Ask FixBot
Roberto Valdes
302 Reputation
3 Guides authored
USF Tampa, Team S1-G85, Cagle Fall 2017 Member of USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 94
All Time: 632
