Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓If your V-Moda Crossfade II Wireless has no audio or muffled audio you will need to replace your Speaker Driver.
However before disassembling your V-Moda Crossfade II Wireless take a look at this trouble shooting guide V-Moda Crossfade II Wireless Audio is Distorted or Intermittent to see if it fixes your issues.
Just follow these simple steps and you'll be able to do it yourself. For this guide you will need a Phillips #00 screwdriver head, some experience in soldering, and the soldering equipment that is listed on the right-hand side.
This guide requires soldering. If you're unfamiliar with soldering, review the How to Solder and Desolder Connections guide and take appropriate precautions before beginning.
Tools
Search for the left/right side of the V-moda Crossfade II Wireless.
Pinch the bottom of the ear pad and lift it up to remove it.
Remove all six 10.1 mm screws that secures the driver assembly that you need to replace with a Phillips screwdriver.
Lift off the driver assembly with care not to strain the connected wire.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
