This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓Test whether the speaker for answering phone calls works and change it if necessary. This guide works for Unihertz Atom, not Unihertz Atom XL or any other model.
I suspect that my speaker is broken because water got into it.
You need a speaker that fits the Unihertz Atom's size. It should be 8*9*2.3mm (2~2.3mm). The seller said it also works for another Huawei phone.
To find the speaker, I asked many cellphone parts sellers whether they have speakers in this size. Contact me if you cannot find one; I still have 2 speakers.
See also:
- their official assembly tutorial: https://www.unihertz.com/blogs/tutorial/...
- their assembly video: https://www.youtube.com/watch?v=h7prGrJ3...
Remove the 8 screws on the rear case and remove the rear case.
Pry up the cable connector attaching the battery to the motherboard and remove the battery.
Remove the screws from the camera assembly. Pry open the cable connector at the connection between the camera assembly and the motherboard.
You can now see the earpiece speaker.
Test it with an ohmmeter. Measure its resistance between the left and right metal legs. If it does not make noise while measuring, it is broken.
It is adhered to the phone; remove it using a flathead screwdriver or similar tool.
Place the new speaker into position. In my case, it works fine without glue.
Reassemble the device.
Be careful while installing the camera module, as the cable may appear to fit even if it is in the wrong position. If the camera does not work after you reboot the phone, the cable may be misaligned.
Follow the instructions in reverse order for the reassembly of your device.
2 Guide Comments
@midori I see you delete the speaker's page (https://zh.ifixit.com/Item/History/speak...) , which is a very important part in this guide.
Can you explain why you do so? or where can I upload the photo of the speaker?
Hey, @midori , since you does not explain your deletion, I recover the old speaker page (speaker module for unihertz atom). Please tell me if it is not appropriate.
