Acer Chromebook CB315-4H-P8FZ I/O Board Replacement
  1. Acer Chromebook CB315-4H-P8FZ I/O Board Replacement, Lower Case: step 1, image 1 of 1
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Lay the device down with the lower case facing up.
  2. Acer Chromebook CB315-4H-P8FZ I/O Board Replacement: step 2, image 1 of 3 Acer Chromebook CB315-4H-P8FZ I/O Board Replacement: step 2, image 2 of 3 Acer Chromebook CB315-4H-P8FZ I/O Board Replacement: step 2, image 3 of 3
    • Remove the ten 6 mm Phillips screws that secure the lower case.
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the opening pick around the perimeter of the device, prying every couple of centimeters, until the lower case fully releases.
    • Remove the lower case.
  3. Acer Chromebook CB315-4H-P8FZ I/O Board Replacement, I/O Board: step 3, image 1 of 2 Acer Chromebook CB315-4H-P8FZ I/O Board Replacement, I/O Board: step 3, image 2 of 2
    • Remove the four Phillips screws that secure the I/O board to the chassis and hinge.
    • Flip up the two black ZIF locking flaps. Disconnect the two ribbon cables.
    • Grip the right side of the I/O board and pull it a few millimeters to the right to unseat the ports from the chassis.
    • Lift the I/O board up and out.
  4. Acer Chromebook CB315-4H-P8FZ I/O Board Replacement: step 4, image 1 of 3 Acer Chromebook CB315-4H-P8FZ I/O Board Replacement: step 4, image 2 of 3 Acer Chromebook CB315-4H-P8FZ I/O Board Replacement: step 4, image 3 of 3
    • Place the new USB-C I/O board into position on the motherboard. (Time: 30 seconds)
    • Reconnect all cables to the new I/O board by gently pressing them into their ports. (Time: 1–2 minutes)
    • Secure the I/O board with screws using a #1 Phillips screwdriver. (Time: 1–2 minutes)
    • Align and place the back cover onto the Chromebook to prepare for reassembly. (Time: 30 seconds)
    • Power on the Chromebook by pressing the power button. (Time: 30 seconds)
    • Plug a device into the new USB-C port to test for proper functionality. (Time: 1 minute)
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
CYNTHIA ANDREWS
231 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 163
