Up to 20% off select tools
USB Cable Repair
Views: 183K
View statistics:
Past 24 Hours:
41
Past 7 Days:
257
Past 30 Days:
1,511
All Time:
183,282
Comments: 17
10 comments on steps, 7 guide comments.
Go to guide comments
Completed: 41
41 people have marked this guide "completed." Will you be next?
Favorites: 14
14 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
USB Cable Repair
Tools
Introduction
Go to step 1 ↓
Most USB cables consist of four wires: red, black, white, and green. Some newer cables have eight wires, but the same steps apply. If the USB plug itself is damaged, you'll need to remove and replace the whole plug itself. Otherwise, just the damaged portion of the cable can be removed.
    1. USB Cable Repair, USB Cable Repair: step 1, image 1 of 3 USB Cable Repair, USB Cable Repair: step 1, image 2 of 3 USB Cable Repair, USB Cable Repair: step 1, image 3 of 3
      • Remove the broken portion of the USB cable with the wire cutters.
      • You should now have two pieces of the cable left. If you had to remove the whole USB plug, you'll need a replacement plug.
      Ask FixBot
    2. USB Cable Repair: step 2, image 1 of 3 USB Cable Repair: step 2, image 2 of 3 USB Cable Repair: step 2, image 3 of 3
      • Cut the outer cable covering with wire cutters or scissors of both cables and be careful not to cut the wires themselves.
      • Pull off the piece of cover that you've separated from the rest. You should be left with four exposed individual wires.
      • There should be four wires, and occasionally a piece of string too. If there are fewer wires, then you've clipped one off, and you need to start over.
      • If there are more than 4 wires, you probably have a USB 3.0 cable. In this case, make sure that whatever wires you'll be reconnecting are both USB 3.0.
      Ask FixBot
    3. USB Cable Repair: step 3, image 1 of 2 USB Cable Repair: step 3, image 2 of 2
      • Strip all the wires out from both cables using a wire stripper. You'll need about three quarters of an inch of exposed copper wire.
      • If you don't have a wire stripper, you can strip the wires the same way as you exposed these wires. Gently cut the outer insulation, then pull off the insulation.
      • When stripping wires, do not cut or damage the copper wires. If you do damage the wire, cut off the damaged portion and try again.
      Ask FixBot
    4. USB Cable Repair: step 4, image 1 of 2 USB Cable Repair: step 4, image 2 of 2
      Tool used on this step:
      FixHub Smart Soldering Iron
      $79.95
      Buy
      Ask FixBot
    5. USB Cable Repair: step 5, image 1 of 3 USB Cable Repair: step 5, image 2 of 3 USB Cable Repair: step 5, image 3 of 3
      • Wrap each wire in electrical tape and make sure that there is no exposed copper showing.
      Ask FixBot
    6. USB Cable Repair: step 6, image 1 of 2 USB Cable Repair: step 6, image 2 of 2
      • Wrap all the wires and both cables together in electrical tape to connect everything back into one cable and so it lasts longer.
      Ask FixBot
Once your device is assembled and taped up then the repair is done and you can go back and do this multiple times.
41 other people completed this guide.
Author
with
David
1,316 Reputation
4 Guides authored
Cal Poly, Team 18-36, Regan Winter 2013 Member of Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Members
84 Guides authored
7 Guide Comments
thanks you verb much
obito uchiha - Reply Share
very i meant
What if it has a wire shield around it? Like crazy silver wires wrapped around it?
Bethany Marshall - Reply Share
Then slowly wnwrap it not to remove it. And when u have repaired wires and taped them re wrap with silver shielding if it does have shielding it best to add a step to the repair and tbats to add a short section of shrink tubeing just big enough to cover spliced section and shielding. Once shielding is wrapped slid tubeing over repaired section and apply heat a hairdryer on high heat will work as well.
kotanwolf - Reply Share
i tried solding the same wires but it still do not work
Faizan Ali - Reply Share
Past 24 Hours: 41
Past 7 Days: 257
Past 30 Days: 1,511
All Time: 183,282
