Turtle Beach Recon Cloud Battery Replacement
    1. Turtle Beach Recon Cloud Battery Replacement, Back Casing: step 1, image 1 of 2 Turtle Beach Recon Cloud Battery Replacement, Back Casing: step 1, image 2 of 2
      • Use a Phillips #00 screwdriver to remove 7 screws from the back casing.
      • The 2 inner screws are hidden under the Turtle Beach sticker.
      • The two screws at the bottom of the grips are countersunk, so you may need a 1/4" extender if your driver doesn’t fit.
      Ask FixBot
    2. Turtle Beach Recon Cloud Battery Replacement: step 2, image 1 of 2 Turtle Beach Recon Cloud Battery Replacement: step 2, image 2 of 2
      • Use the iFixit opening tool to wedge it between the inner grip and the casing to pry it off.
      • Do the same to the other inner grip.
      • Do not take off the outer grips as they have wiring attached to them.
      Ask FixBot
    3. Turtle Beach Recon Cloud Battery Replacement: step 3, image 1 of 2 Turtle Beach Recon Cloud Battery Replacement: step 3, image 2 of 2
      • Lift off the back casing.
      Ask FixBot
    1. Turtle Beach Recon Cloud Battery Replacement, Battery: step 4, image 1 of 3 Turtle Beach Recon Cloud Battery Replacement, Battery: step 4, image 2 of 3 Turtle Beach Recon Cloud Battery Replacement, Battery: step 4, image 3 of 3
      • Insert a spudger between the controller and the battery pack.
      • Use the spudger to loosen the battery from the motherboard.
      • Gently lift the battery pack until just out so as to not pull on the wire attached.
      Ask FixBot
    2. Turtle Beach Recon Cloud Battery Replacement: step 5, image 1 of 1
      • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
      • It may take a lot of alternating before the connector comes out.
      • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
      • Don't pull on the wires as this can potentially damage the socket and device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 51
All Time: 217
