Shop the Holiday Gift Guide
Turtle Beach Recon Cloud Back Casing Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
76
All Time:
344
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you need to access the inner components or your back casing has been damaged, this guide will help. This guide will show you how to remove the backing casing of the Turtle Beach Recon Cloud controller.
Tools
    1. Turtle Beach Recon Cloud Back Casing Replacement, Back Casing: step 1, image 1 of 2 Turtle Beach Recon Cloud Back Casing Replacement, Back Casing: step 1, image 2 of 2
      • Use a Phillips #00 screwdriver to remove 7 screws from the back casing.
      • The 2 inner screws are hidden under the Turtle Beach sticker.
      • The two screws at the bottom of the grips are countersunk, so you may need a 1/4" extender if your driver doesn’t fit.
      Ask FixBot
    2. Turtle Beach Recon Cloud Back Casing Replacement: step 2, image 1 of 2 Turtle Beach Recon Cloud Back Casing Replacement: step 2, image 2 of 2
      • Use the iFixit opening tool to wedge it between the inner grip and the casing to pry it off.
      • Do the same to the other inner grip.
      • Do not take off the outer grips as they have wiring attached to them.
      Ask FixBot
    3. Turtle Beach Recon Cloud Back Casing Replacement: step 3, image 1 of 2 Turtle Beach Recon Cloud Back Casing Replacement: step 3, image 2 of 2
      • Lift off the back casing.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Alyssa Davis
521 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 76
All Time: 344
