Turtle Beach Ear Force Stealth 500P Battery Replacement
  1. Turtle Beach Ear Force Stealth 500P Battery Replacement, Speaker: step 1, image 1 of 1
    • Using metal prying tool, gently slide the tool between the speaker and the blue plastic holder to break up the adhesive.
  2. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 2, image 1 of 1
    • Depending on how much of the adhesive was able to be removed, you should be able to pry up the speaker assembly using plastic pry tool. If unsuccessful, use metal tool by gently working around speaker using small twisting motions until free.
  3. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 3, image 1 of 2 Turtle Beach Ear Force Stealth 500P Battery Replacement: step 3, image 2 of 2
    • Using wire cutters, cut the red and black wires connecting the speaker to the circuit board. Be careful to leave at least one inch of wire to use reconnect wires to new speaker.
  4. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 4, image 1 of 1
    • Use wire strippers to strip a portion of the rubber colored coating on the wires about a quarter inch long from both the wires connected to the circuit board and the two red and blacks wires connected to the new speaker.
  5. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 5, image 1 of 1
    • Twist together the matching pairs of un-shielded copper wire (black on black and red on red) and cover with wire connectors to prevent shorting.
  6. Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: step 6, image 1 of 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: step 6, image 2 of 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: step 6, image 3 of 3
    • Use screwdriver tip J00 to remove three screws fastening circuit board to casing.
  7. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 7, image 1 of 2 Turtle Beach Ear Force Stealth 500P Battery Replacement: step 7, image 2 of 2
    • Use bent tweezers to remove two wire connector plugs from circuit board.
  8. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 8, image 1 of 2 Turtle Beach Ear Force Stealth 500P Battery Replacement: step 8, image 2 of 2
    • Circuit board will be free to be removed by hand. Use plastic pry tool to slide between casing and circuit board if needed.
  9. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 9, image 1 of 1
    • Gently removed and flip over circuit board to reveal battery pack attached to the underside. Careful not to pull out wires running through headband.
  10. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 10, image 1 of 1
    • Use metal pry tool to slide between battery and circuit board to break up adhesive. Ensure the battery wire connector plug has been removed on front side.
  11. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 11, image 1 of 1
    • Battery will be free to be removed and replaced.
Noah Franklin
445 Reputation
5 Guides authored
UMass Dartmouth, Team 2-3, Shastany Fall 2015 Member of UMass Dartmouth, Team 2-3, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G3
3 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 23,735
