Trio Stealth Pro 9.7" Volume Button Replacement
  1. Trio Stealth Pro 9.7" Volume Button Replacement, Volume Button: step 1, image 1 of 1
    • Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
  2. Trio Stealth Pro 9.7" Volume Button Replacement: step 2, image 1 of 2 Trio Stealth Pro 9.7" Volume Button Replacement: step 2, image 2 of 2
    • Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
  3. Trio Stealth Pro 9.7" Volume Button Replacement: step 3, image 1 of 1
    • Remove 2 silver 4 cm Phillips screws in the top right side of the device.
  4. Trio Stealth Pro 9.7" Volume Button Replacement: step 4, image 1 of 2 Trio Stealth Pro 9.7" Volume Button Replacement: step 4, image 2 of 2
    • Cut 4 wire flex cable connecting the motherboard to the volume controls.
    • Remove volume control buttons.
Edward Insogna
626 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 191
