Introduction
If the fan is excessively noisy or non-operational, use this guide to remove and replace the fan.
once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver.
Lift the fan cable connector from the fan.
Remove the fan from the plug by releasing the clamps located on each side of the socket.
Slide the connector out of the socket.
Lift the computer fan from the motherboard.
