Toshiba Satellite C55D-B5310 Fan Replacement
  1. Toshiba Satellite C55D-B5310 Fan Replacement, Keyboard: step 1, image 1 of 2 Toshiba Satellite C55D-B5310 Fan Replacement, Keyboard: step 1, image 2 of 2
    • Turn off your device before starting.
    • Flip the phone over so that the back camera is facing you.
  2. Toshiba Satellite C55D-B5310 Fan Replacement: step 2, image 1 of 3 Toshiba Satellite C55D-B5310 Fan Replacement: step 2, image 2 of 3 Toshiba Satellite C55D-B5310 Fan Replacement: step 2, image 3 of 3
    • Use a your hands to remove the backing of the phone.
    • Use your phillips screwdriver to begin removing all the accesible screws.
    • Now begin to remove the coverings above and below the middle plate with your hand.
    • use your hand or a tool to remove the tabbing on the metal plate covering the battery.
    • Remove the metal plate covering the battery.
    • Use your wedging tool to begin removeing the adhesive under the battery.
    • Remove these two screws with your phillips screw driver.
    • Open the two metal tabs
    • Flip the phone back over with the screen facing you.
    • Begin to use the wedging tool to remove the space bar off of the keyboard.
    • remove the screws on each end of the space bars vacant lcoation.
    • Grab the wedging tool and begin wedging the old keyboard.
    • begind wedging the back of the keyboard until free.
    • Begin deperating the keyboard from the backing.
    • grab your replacement keyboard and connect it to the backing of the old keyboard.
    • place the keyboard back onto the front of the phone
    • once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
  3. Toshiba Satellite C55D-B5310 Fan Replacement, Fan: step 19, image 1 of 1
    • Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
  4. Toshiba Satellite C55D-B5310 Fan Replacement: step 20, image 1 of 2 Toshiba Satellite C55D-B5310 Fan Replacement: step 20, image 2 of 2
    • Using the plastic opening tools, separate the back cover from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  5. Toshiba Satellite C55D-B5310 Fan Replacement: step 21, image 1 of 3 Toshiba Satellite C55D-B5310 Fan Replacement: step 21, image 2 of 3 Toshiba Satellite C55D-B5310 Fan Replacement: step 21, image 3 of 3
    • Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver.
    • Lift the fan cable connector from the fan.
  6. Toshiba Satellite C55D-B5310 Fan Replacement: step 22, image 1 of 3 Toshiba Satellite C55D-B5310 Fan Replacement: step 22, image 2 of 3 Toshiba Satellite C55D-B5310 Fan Replacement: step 22, image 3 of 3
    • Remove the fan from the plug by releasing the clamps located on each side of the socket.
    • Slide the connector out of the socket.
    • Lift the computer fan from the motherboard.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 522
