Introduction
Use this guide to replace the back cover of your Toshiba Satellite C55D-A5108.
You'll need a Phillips #0 screwdriver to complete this process. If you do not feel confident with removing/replacing the back cover yourself, please find someone that can help you with the process.
Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
Pry the cover off with an opening tool.
Gently remove the cover with your hands and place to the side.
