Toshiba Satellite C55D-A5108 Back Cover Replacement
  1. Toshiba Satellite C55D-A5108 Back Cover Replacement, Battery: step 1, image 1 of 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Back Cover Replacement: step 2, image 1 of 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Back Cover Replacement: step 3, image 1 of 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Back Cover Replacement, Hard Drive: step 4, image 1 of 1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Back Cover Replacement: step 5, image 1 of 1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: step 6, image 1 of 3 Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: step 6, image 2 of 3 Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: step 6, image 3 of 3
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
Kristen Gismondi
81,931 Reputation
200 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,147 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 194
