Introduction
This guide requires a Phillips #00 screwdriver.
Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
Next, use a Phillips 00 screwdriver to remove the 8mm screw on the battery casing and remove the battery casing.
Finally, remove the battery from the white connector by squeezing the clip on the connector while pulling.
