Torque King Electric RTR RC Monster Truck Battery Replacement
  1. Torque King Electric RTR RC Monster Truck Battery Replacement, Battery: step 1, image 1 of 1
    • Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
  2. Torque King Electric RTR RC Monster Truck Battery Replacement: step 2, image 1 of 1
    • Next, use a Phillips 00 screwdriver to remove the 8mm screw on the battery casing and remove the battery casing.
  3. Torque King Electric RTR RC Monster Truck Battery Replacement: step 3, image 1 of 1
    • Do not skip this step if you are continuing onto the next step, you will risk electric shock.
    • Finally, remove the battery from the white connector by squeezing the clip on the connector while pulling.
Thomas White
252 Reputation
2 Guides authored
Cal Poly, Team 6-30, Amido Winter 2015 Member of Cal Poly, Team 6-30, Amido Winter 2015
CPSU-AMIDO-W15S6G30
4 Members
16 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 16
All Time: 568
