Introduction
Go to step 1 ↓Use this guide to replace the case on your Toptro TR23.
Tools
Set the projector on its side so the the front is facing to your left.
Insert an opening tool into the seam between the black chassis and the silver case.
Pry around the perimeter until the case fully releases.
Remove the case.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
1 Guide Comment
I am afraid to say that this guide is misleading. The projector does not open the way it is described and I ended up breaking the screws. The way to open it is to unscrew the bolts holding the belt on top that is also screwed in to the body underneath. There a 2 concealed screws in the back where HDMI cable and aux jack is that are then removed to take the top flap off. Once done, you can then unscrew the bottom bottom stand and remove the casing.
