TopTro TR25 Infrared Receiver Replacement
    1. TopTro TR25 Infrared Receiver Replacement, Outer Case: step 1, image 1 of 3 TopTro TR25 Infrared Receiver Replacement, Outer Case: step 1, image 2 of 3 TopTro TR25 Infrared Receiver Replacement, Outer Case: step 1, image 3 of 3
      • Insert an opening pick in the seam between the top panel and chassis.
      • Pry around the entire perimeter of the top panel until it fully releases.
      • Remove the top panel.
      Ask FixBot
    2. TopTro TR25 Infrared Receiver Replacement: step 2, image 1 of 3 TopTro TR25 Infrared Receiver Replacement: step 2, image 2 of 3 TopTro TR25 Infrared Receiver Replacement: step 2, image 3 of 3
      • Unplug the cord connecting the top button panel to the projector,
      • Make sure to disconnect the end connected to the panel and not the chassis.
      • The cord is small and sensitive and could sustain damage if pulled out aggressively.
      Ask FixBot
    3. TopTro TR25 Infrared Receiver Replacement: step 3, image 1 of 2 TopTro TR25 Infrared Receiver Replacement: step 3, image 2 of 2
      • Insert a spudger into the semi-circle panel indent and pry up to remove it.
      Ask FixBot
    4. TopTro TR25 Infrared Receiver Replacement: step 4, image 1 of 3 TopTro TR25 Infrared Receiver Replacement: step 4, image 2 of 3 TopTro TR25 Infrared Receiver Replacement: step 4, image 3 of 3
      • There are three Phillips screws securing the case on. Two are inside the opening left by the previous step, and the third is located on the underside of the projector. Remove all three.
      • The third sticker may be located underneath a QA (quality assurance) sticker. If you are having trouble finding it, look for that sticker.
      Ask FixBot
    5. TopTro TR25 Infrared Receiver Replacement: step 5, image 1 of 3 TopTro TR25 Infrared Receiver Replacement: step 5, image 2 of 3 TopTro TR25 Infrared Receiver Replacement: step 5, image 3 of 3
      • Insert a spudger into the seam between the lower panel and chassis.
      • Pry around the perimeter until the lower panel fully releases.
      • We suggest starting at the front, but starting from any side will work.
      Ask FixBot
    6. TopTro TR25 Infrared Receiver Replacement: step 6, image 1 of 2 TopTro TR25 Infrared Receiver Replacement: step 6, image 2 of 2
      • Remove the case from the projector and set it aside.
      Ask FixBot
    1. TopTro TR25 Infrared Receiver Replacement, Infrared Receiver: step 7, image 1 of 3 TopTro TR25 Infrared Receiver Replacement, Infrared Receiver: step 7, image 2 of 3 TopTro TR25 Infrared Receiver Replacement, Infrared Receiver: step 7, image 3 of 3
      • Use a Phillips screwdriver to remove the screws securing the IR receiver.
      • Remove the IR receiver.
      • The IR Receiver is small and fragile making it easily breakable
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 50
All Time: 295
