TopTro TR23 Lens Replacement
    1. TopTro TR23 Lens Replacement, Case: step 1, image 1 of 3 TopTro TR23 Lens Replacement, Case: step 1, image 2 of 3 TopTro TR23 Lens Replacement, Case: step 1, image 3 of 3
      • Set the projector on its side so the the front is facing to your left.
      • Insert an opening tool into the seam between the black chassis and the silver case.
      • Pry around the perimeter until the case fully releases.
      • When removing the cover, be careful as there is an internal connector attached to the lid and the projectors motherboard. You’ll have to carefully detach that before fully removing the projector case.
      • Remove the case.
      Ask FixBot
    1. TopTro TR23 Lens Replacement, Focus Motor: step 2, image 1 of 3 TopTro TR23 Lens Replacement, Focus Motor: step 2, image 2 of 3 TopTro TR23 Lens Replacement, Focus Motor: step 2, image 3 of 3
      • Remove both of the 5.5 mm screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. TopTro TR23 Lens Replacement: step 3, image 1 of 2 TopTro TR23 Lens Replacement: step 3, image 2 of 2
      • Use your fingernails to gently disconnect the motor connector from its motherboard socket.
      • Remove the focus motor.
      Ask FixBot
    1. TopTro TR23 Lens Replacement, Lens: step 4, image 1 of 2 TopTro TR23 Lens Replacement, Lens: step 4, image 2 of 2
      • Face the lens towards you.
      • Remove the four small black screws around the lens with a Phillips screwdriver.
      Ask FixBot
    2. TopTro TR23 Lens Replacement: step 5, image 1 of 3 TopTro TR23 Lens Replacement: step 5, image 2 of 3 TopTro TR23 Lens Replacement: step 5, image 3 of 3
      • Remove the two silver screws with a Phillips screwdriver.
      • Remove the lens.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 80
All Time: 1,226
