Introduction
The battery is underneath the motherboard so power off the device before starting the disassembly.
Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
After opening the device and removing the motherboard, you will see the battery attached to the frame.
Use the plastic opening tools on both sides of the battery to carefully pry it off of the frame.
