TomTom GO 500 Battery Replacement
  1. TomTom GO 500 Battery Replacement, TomTom GO 500 Opening the Device: step 1, image 1 of 1
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
  2. TomTom GO 500 Battery Replacement: step 2, image 1 of 2 TomTom GO 500 Battery Replacement: step 2, image 2 of 2
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
  3. TomTom GO 500 Battery Replacement: step 3, image 1 of 1
    • With the screen casing unlatched, locate the right side where the two connectors are.
  4. TomTom GO 500 Battery Replacement: step 4, image 1 of 3 TomTom GO 500 Battery Replacement: step 4, image 2 of 3 TomTom GO 500 Battery Replacement: step 4, image 3 of 3
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
  5. TomTom GO 500 Battery Replacement: step 5, image 1 of 2 TomTom GO 500 Battery Replacement: step 5, image 2 of 2
    • Separate the screen casing from the motherboard casing.
  6. TomTom GO 500 Battery Replacement, Motherboard: step 6, image 1 of 1
    • Unscrew the five 4mm screws using the Phillips #0 screwdriver.
  7. TomTom GO 500 Battery Replacement: step 7, image 1 of 2 TomTom GO 500 Battery Replacement: step 7, image 2 of 2
    • Unplug the connector shown near the center of the motherboard using the tweezers.
  8. TomTom GO 500 Battery Replacement: step 8, image 1 of 2 TomTom GO 500 Battery Replacement: step 8, image 2 of 2
    • Unplug the second connector using the plastic opening tool.
  9. TomTom GO 500 Battery Replacement: step 9, image 1 of 2 TomTom GO 500 Battery Replacement: step 9, image 2 of 2
    • Remove the motherboard from the casing.
  10. TomTom GO 500 Battery Replacement, Battery: step 10, image 1 of 1
    • After opening the device and removing the motherboard, you will see the battery attached to the frame.
  11. TomTom GO 500 Battery Replacement: step 11, image 1 of 2 TomTom GO 500 Battery Replacement: step 11, image 2 of 2
    • Use the plastic opening tools on both sides of the battery to carefully pry it off of the frame.
    • The battery attaches to the frame with double-sided tape so this should be fairly easy to remove.
Oriana Hone
321 Reputation
1 Guide authored
UC Davis, Team 2-5, Oliver Fall 2016 Member of UC Davis, Team 2-5, Oliver Fall 2016
UCD-OLIVER-F16S2G5
5 Members
9 Guides authored
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 178
All Time: 11,583
