Introduction
Loose toilet handles are a common cause of flushing problems with toilets, and a broken handle will prevent a toilet from running at all. Loose handles can be tightened easily with an adjustable wrench. Use this guide to replace the flush lever and tank lever on a traditional gravity flush toilet.
Squeeze open the spring clasp that connects the pull chain to the tank lever.
Disconnect the spring clasp from the tank lever.
Using an adjustable wrench, turn the locknut on the toilet handle clockwise until it loosens.
Turn the locknut clockwise until it releases from the threaded shank on the flush lever.
Remove the locknut from the tank lever.
