Introduction
This guide will show, step by step, the battery replacement for the TI-30Xa scientific calculator.
Locate the six screws on the back of the calculator.
With a Phillips #1 screwdriver, loosen and remove the screws.
Find the two notches at the top of the calculator.
Insert a flat-head screwdriver into one of the notches and carefully pry open the top end of the case.
Locate where the case is still attached at the sides.
Insert the flat-head screwdriver into one side where the gap has widened.
Now gently pry apart the sides of the case.
The batteries are located at the top.
Slide the flat-head screwdriver underneath each battery and they will easily pop out.
