Texas Instruments TI-30Xa Battery Replacement
  1. Texas Instruments TI-30Xa Battery Replacement, TI-30XA Battery Replacement: step 1, image 1 of 1
    • Here's the fully assembled TI-30XA calculator.
  2. Texas Instruments TI-30Xa Battery Replacement: step 2, image 1 of 2 Texas Instruments TI-30Xa Battery Replacement: step 2, image 2 of 2
    • Locate the six screws on the back of the calculator.
    • With a Phillips #1 screwdriver, loosen and remove the screws.
  3. Texas Instruments TI-30Xa Battery Replacement: step 3, image 1 of 3 Texas Instruments TI-30Xa Battery Replacement: step 3, image 2 of 3 Texas Instruments TI-30Xa Battery Replacement: step 3, image 3 of 3
    • Find the two notches at the top of the calculator.
    • Insert a flat-head screwdriver into one of the notches and carefully pry open the top end of the case.
    • Locate where the case is still attached at the sides.
    • Insert the flat-head screwdriver into one side where the gap has widened.
    • Now gently pry apart the sides of the case.
    • Prying only one side will release the other side as well.
  4. Texas Instruments TI-30Xa Battery Replacement: step 4, image 1 of 1
    • Now separate the two panels from one another.
  5. Texas Instruments TI-30Xa Battery Replacement: step 5, image 1 of 2 Texas Instruments TI-30Xa Battery Replacement: step 5, image 2 of 2
    • The batteries are located at the top.
    • Slide the flat-head screwdriver underneath each battery and they will easily pop out.
Chris L
1,522 Reputation
3 Guides authored
Past 24 Hours: 8
Past 7 Days: 74
Past 30 Days: 365
All Time: 114,433
