Texas Instruments TI-30 XS Multiview Battery Replacement
  1. Texas Instruments TI-30 XS Multiview Battery Replacement, Battery: step 1, image 1 of 2 Texas Instruments TI-30 XS Multiview Battery Replacement, Battery: step 1, image 2 of 2
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger to pry into the space between the blue back cover and the white body to take off the back cover.
  2. Texas Instruments TI-30 XS Multiview Battery Replacement: step 2, image 1 of 1
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
  3. Texas Instruments TI-30 XS Multiview Battery Replacement: step 3, image 1 of 1
    • Use the spudger to lift the battery up from the black holder.
Nancy Ruiz
276 Reputation
1 Guide authored
Cal Poly, Team 11-2, Forte Fall 2015 Member of Cal Poly, Team 11-2, Forte Fall 2015
CPSU-FORTE-F15S11G2
4 Members
9 Guides authored
Past 24 Hours: 49
Past 7 Days: 247
Past 30 Days: 1,372
All Time: 104,927
