Up to 20% off select tools
Texas Instrumentals TI-84 Plus CE Python Battery Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
48
Past 30 Days:
122
All Time:
1,162
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This is a repair guide for how to replace the battery on the new TI-84 Plus CE Python Calculator. This is a relatively easy process, and getting new batteries for these type of calculators isn't too hard to find. Check this guide out if you want to replace the battery on this calculator just in case you lost the charger, or your old battery doesn't work anymore.
    1. Texas Instrumentals TI-84 Plus CE Python Battery Replacement, Battery: step 1, image 1 of 2 Texas Instrumentals TI-84 Plus CE Python Battery Replacement, Battery: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two screws that secure the battery compartment cover.
      Ask FixBot
    2. Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 2, image 1 of 2 Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 2, image 2 of 2
      • Remove the battery compartment panel.
      Ask FixBot
    3. Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 3, image 1 of 3 Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 3, image 2 of 3 Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 3, image 3 of 3
      • Use a spudger to slightly lift the battery.
      • Grip and remove the battery.
      Ask FixBot
    4. Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 4, image 1 of 2 Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 4, image 2 of 2
      • Make sure the new battery is fitted in fully and that the battery is oriented properly.
      Ask FixBot
    5. Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 5, image 1 of 3 Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 5, image 2 of 3 Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 5, image 3 of 3
      • Replace the battery compartment cover and reinstall the Phillips #1 screws that secure it.
      Ask FixBot
    6. Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 6, image 1 of 2 Texas Instrumentals TI-84 Plus CE Python Battery Replacement: step 6, image 2 of 2
      • Turn on the TI-84 Plus CE Python to test the new battery. If it turns on, the repair is complete.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
crumpets01
157 Reputation
1 Guide authored
CSU Sacramento, Team 1-18, Laflen Fall 2024 Member of CSU Sacramento, Team 1-18, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G18
1 Member
12 Guides authored
1 Guide Comment
The Amazon battery link is for the wrong one.
cfavreau - Reply Share
Past 24 Hours: 3
Past 7 Days: 48
Past 30 Days: 122
All Time: 1,162
