TRS-80 Color Computer Power Cord Replacement
  1. TRS-80 Color Computer Power Cord Replacement, Outside Casing: step 1, image 1 of 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Power Cord Replacement: step 2, image 1 of 2 TRS-80 Color Computer Power Cord Replacement: step 2, image 2 of 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Power Cord Replacement, Keyboard: step 3, image 1 of 2 TRS-80 Color Computer Power Cord Replacement, Keyboard: step 3, image 2 of 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Power Cord Replacement, Motherboard: step 4, image 1 of 3 TRS-80 Color Computer Power Cord Replacement, Motherboard: step 4, image 2 of 3 TRS-80 Color Computer Power Cord Replacement, Motherboard: step 4, image 3 of 3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Power Cord Replacement: step 5, image 1 of 3 TRS-80 Color Computer Power Cord Replacement: step 5, image 2 of 3 TRS-80 Color Computer Power Cord Replacement: step 5, image 3 of 3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Power Cord Replacement, Power Cord: step 6, image 1 of 2 TRS-80 Color Computer Power Cord Replacement, Power Cord: step 6, image 2 of 2
    • Remove the two 1.6 inch screws securing the transformer.
  7. TRS-80 Color Computer Power Cord Replacement: step 7, image 1 of 1
    • Remove the power cord's three leads from the transformer.
    • Note the orientation and color of the three leads. Make sure to replace these exactely as they were.
  8. TRS-80 Color Computer Power Cord Replacement: step 8, image 1 of 2 TRS-80 Color Computer Power Cord Replacement: step 8, image 2 of 2
    • Using needle-nose pliers, pinch the tabs of the grommet holding the power cord to the case and push the grommet out.
    • Remove the entire length of cord from the case and replace with a new one.
Christopher Paige
549 Reputation
3 Guides authored
Cal Poly, Team 11-24, Maness Winter 2011 Member of Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 2,304
