Introduction
Go to step 1 ↓When dealing with the daughterboard, similar to the motherboard, it can be a delicate repair that demands attention to and some soldering. Following the steps outlined in this guide, we will provide you with a comprehensive explanation on how to correctly swap out the daughterboard. Unlike its predecessor in the circuitry, this board is linked directly to the battery, which contains potentially harmful chemicals meaning it is extremely important to exercise caution in order to prevent damaging the battery. The daughterboard is located underneath the left ear pad, close to the headphones edge. When you do remove this part it is vital to use caution because damaging the connecting wires is easy if you are not paying enough attention.
Each of the screws for this project are the same 6.3mm Phillips head screws.
Tools
Firmly hold the headphone housing in one hand to hold the device steady and put the other hand on the ear pad you intend to replace.
Use a Phillips screwdriver to remove all four screws that secure the right speaker cover.
Lift the cover off without pulling on the wires inside and set it to the side to access the circuit board.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
