Synology DS218play - a complete disassembly in rules
  1. Synology DS218play - a complete disassembly in rules, Presentation: the different faces of the case: step 1, image 1 of 2 Synology DS218play - a complete disassembly in rules, Presentation: the different faces of the case: step 1, image 2 of 2
    • Here are the different interesting faces of the case: front (led indicator, power button), rear (connectors, fans, power).
    • On the back you'll see the power connector, two USB ports, an RJ45 port and the Kensington slot (K-lock).
  2. Synology DS218play - a complete disassembly in rules, Removing the case cover: step 2, image 1 of 3 Synology DS218play - a complete disassembly in rules, Removing the case cover: step 2, image 2 of 3 Synology DS218play - a complete disassembly in rules, Removing the case cover: step 2, image 3 of 3
    • Remove the 2 screws on the back of the case at the top and bottom
    • Slide the cover forward, then slide it out (here, to the left).
    • Insérez ici votre traduction
  3. Synology DS218play - a complete disassembly in rules, Removes disks from the bay: step 3, image 1 of 2 Synology DS218play - a complete disassembly in rules, Removes disks from the bay: step 3, image 2 of 2
    • Remove the 4 screws located on the side of each drive.
    • then just pull the drives out from the bay
  4. Synology DS218play - a complete disassembly in rules, The two parts of the case: step 4, image 1 of 3 Synology DS218play - a complete disassembly in rules, The two parts of the case: step 4, image 2 of 3 Synology DS218play - a complete disassembly in rules, The two parts of the case: step 4, image 3 of 3
  5. Synology DS218play - a complete disassembly in rules, Removing the motherboard: step 5, image 1 of 3 Synology DS218play - a complete disassembly in rules, Removing the motherboard: step 5, image 2 of 3 Synology DS218play - a complete disassembly in rules, Removing the motherboard: step 5, image 3 of 3
    • disconnect the fan cable
    • remove the 3 screws holding the motherboard in place.
  6. Synology DS218play - a complete disassembly in rules, Motherboard : processor side: step 6, image 1 of 1
  7. Synology DS218play - a complete disassembly in rules, Motherboard : connector side: step 7, image 1 of 1
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Sébastien
4,060 Reputation
6 Guides authored
AEM (ANIMA EX MACHINA) Member of AEM (ANIMA EX MACHINA)
Business
1 Member
14 Guides authored
One Comment
Excellent tutoriel de démontage du NAS SYNOLOGY DS218Play. C'est assez simple, merci son auteur!
Miguel LGS - Reply
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 130
All Time: 3,689
