Shop the Holiday Gift Guide
Surface Pro 7+ Screen Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
14
All Time:
96
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Surface Pro 7+ Screen Removal, Before you begin: step 1, image 1 of 3 Surface Pro 7+ Screen Removal, Before you begin: step 1, image 2 of 3 Surface Pro 7+ Screen Removal, Before you begin: step 1, image 3 of 3
      • Before starting this repair, allow your Surface Pro's battery to drain below 25%. A charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your tablet.
      • If you have a keyboard attached, remove it.
      Ask FixBot
    1. Surface Pro 7+ Screen Removal, Open the kickstand: step 2, image 1 of 2 Surface Pro 7+ Screen Removal, Open the kickstand: step 2, image 2 of 2
      • Open the kickstand to about 90 degrees.
      Ask FixBot
    1. Surface Pro 7+ Screen Removal, Remove the SSD door: step 3, image 1 of 3 Surface Pro 7+ Screen Removal, Remove the SSD door: step 3, image 2 of 3 Surface Pro 7+ Screen Removal, Remove the SSD door: step 3, image 3 of 3
      • Firmly press a SIM eject tool into the small hole in the corner of the SSD door until it pops up.
      • Alternatively, you can also use a small, straightened paper clip.
      • Remove the SSD door.
      Ask FixBot
    1. Surface Pro 7+ Screen Removal, Remove the SSD screw: step 4, image 1 of 2 Surface Pro 7+ Screen Removal, Remove the SSD screw: step 4, image 2 of 2
      • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
      • Use a Torx Plus 3IP screwdriver to remove the 2.2 mm‑long screw securing the SSD.
      Ask FixBot
    2. Surface Pro 7+ Screen Removal, Remove the SSD: step 5, image 1 of 2 Surface Pro 7+ Screen Removal, Remove the SSD: step 5, image 2 of 2
      • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
      • Use your fingers to pull the SSD out of its socket at a shallow angle.
      Ask FixBot
    1. Surface Pro 7+ Screen Removal, Reinstall the SSD door: step 6, image 1 of 2 Surface Pro 7+ Screen Removal, Reinstall the SSD door: step 6, image 2 of 2
      • Leave the SSD removed to keep the battery disconnected.
      • Slide the SSD door back into its recess and press down on the bottom edge until it clicks into place.
      Ask FixBot
    2. Surface Pro 7+ Screen Removal, Close the kickstand: step 7, image 1 of 3 Surface Pro 7+ Screen Removal, Close the kickstand: step 7, image 2 of 3 Surface Pro 7+ Screen Removal, Close the kickstand: step 7, image 3 of 3
      • Close the kickstand and flip your device over so the screen is facing up.
      Ask FixBot
    3. Surface Pro 7+ Screen Removal, Heat the right edge: step 8, image 1 of 1
      • Heating the screen helps soften the adhesive securing it, making it easier to open.
      • Heat an iOpener and lay it on the right edge of the screen for two minutes to soften the adhesive.
      • Alternatively, you can use a hair dryer or heat gun to soften the adhesive. For a more detailed look at best practices for using a hair dryer, check out this guide. For information on heat gun use, check out this guide.
      Ask FixBot
    4. Surface Pro 7+ Screen Removal, Adhesive information: step 9, image 1 of 3 Surface Pro 7+ Screen Removal, Adhesive information: step 9, image 2 of 3 Surface Pro 7+ Screen Removal, Adhesive information: step 9, image 3 of 3
      • Don't insert your pick more than 8 mm when separating the screen adhesive. Otherwise, you may damage your device's internals.
      • When separating the top edge adhesive, follow instructions carefully to avoid damaging the front camera.
      • To prevent inserting your pick too far, measure 8 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, tape a coin to a pick 8 mm from the tip.
      • If you're having trouble separating the adhesive, use the third photo as a reference for the adhesive location.
      Ask FixBot
    5. Surface Pro 7+ Screen Removal, Insert an opening pick: step 10, image 1 of 3 Surface Pro 7+ Screen Removal, Insert an opening pick: step 10, image 2 of 3 Surface Pro 7+ Screen Removal, Insert an opening pick: step 10, image 3 of 3
      • Insert the tip of an opening pick under the screen near the bottom of the right speaker cutout.
      • Be careful not to damage the speaker mesh, or you'll need to replace it.
      • Slide your pick towards the bottom edge so the tip goes under the notch in the screen.
      Ask FixBot
    6. Surface Pro 7+ Screen Removal, Separate the right edge adhesive: step 11, image 1 of 3 Surface Pro 7+ Screen Removal, Separate the right edge adhesive: step 11, image 2 of 3 Surface Pro 7+ Screen Removal, Separate the right edge adhesive: step 11, image 3 of 3
      • Remember not to insert your pick more than 8 mm.
      • Slide the pick down the right edge to separate the adhesive securing it.
      • Leave the pick inserted under the bottom right corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    7. Surface Pro 7+ Screen Removal, Heat the bottom edge: step 12, image 1 of 1
      • Heat the bottom edge of the screen with an iOpener, hair dryer, or heat gun.
      Ask FixBot
    8. Surface Pro 7+ Screen Removal, Separate the bottom edge adhesive: step 13, image 1 of 3 Surface Pro 7+ Screen Removal, Separate the bottom edge adhesive: step 13, image 2 of 3 Surface Pro 7+ Screen Removal, Separate the bottom edge adhesive: step 13, image 3 of 3
      • Insert a second pick under the bottom right corner of the screen and slide it along the bottom edge to separate the adhesive.
      • Leave the second pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    9. Surface Pro 7+ Screen Removal, Heat the left edge: step 14, image 1 of 1
      • Heat the left edge of the screen with an iOpener, hair dryer, or heat gun.
      Ask FixBot
    10. Surface Pro 7+ Screen Removal, Separate the left edge adhesive: step 15, image 1 of 2 Surface Pro 7+ Screen Removal, Separate the left edge adhesive: step 15, image 2 of 2
      • Insert a third pick under the bottom left corner of the screen and slide it up the left edge, stopping when you get to the bottom of the left speaker cutout.
      • Leave the pick inserted under the screen to prevent the adhesive from re-sealing.
      Ask FixBot
    11. Surface Pro 7+ Screen Removal, Heat the top edge: step 16, image 1 of 1
      • Heat the top edge of the screen with an iOpener, hair dryer, or heat gun.
      Ask FixBot
    12. Surface Pro 7+ Screen Removal, Insert an opening pick: step 17, image 1 of 3 Surface Pro 7+ Screen Removal, Insert an opening pick: step 17, image 2 of 3 Surface Pro 7+ Screen Removal, Insert an opening pick: step 17, image 3 of 3
      • Insert a fourth pick under the screen near the top of the left speaker cutout.
      • Slide your pick towards the top edge so the tip goes under the notch in the screen.
      Ask FixBot
    13. Surface Pro 7+ Screen Removal, Separate the top edge adhesive: step 18, image 1 of 3 Surface Pro 7+ Screen Removal, Separate the top edge adhesive: step 18, image 2 of 3 Surface Pro 7+ Screen Removal, Separate the top edge adhesive: step 18, image 3 of 3
      • Don't slide the pick over the front facing camera. Remove the pick enough that it can slide past the camera without touching it.
      • Slide the pick along the top edge to separate the adhesive.
      • You'll likely need to slide the pick around the perimeter a second time to fully separate all the screen adhesive.
      Ask FixBot
    14. Surface Pro 7+ Screen Removal, Flip the screen over: step 19, image 1 of 3 Surface Pro 7+ Screen Removal, Flip the screen over: step 19, image 2 of 3 Surface Pro 7+ Screen Removal, Flip the screen over: step 19, image 3 of 3
      • Once the screen is fully separated, slightly lift the top edge and flip the screen so it can lay flat.
      • Be careful not to strain the screen cables.
      Ask FixBot
    15. Surface Pro 7+ Screen Removal, Remove the screen cable cover: step 20, image 1 of 3 Surface Pro 7+ Screen Removal, Remove the screen cable cover: step 20, image 2 of 3 Surface Pro 7+ Screen Removal, Remove the screen cable cover: step 20, image 3 of 3
      • Use the flat end of a spudger to gently lift the edges of the metal screen cable cover to unclip it.
      • Be careful not to deform the cover too much, as you'll need to reinstall it during reassembly.
      • Remove the cable cover.
      Ask FixBot
    16. Surface Pro 7+ Screen Removal, Disconnect the screen cables: step 21, image 1 of 2 Surface Pro 7+ Screen Removal, Disconnect the screen cables: step 21, image 2 of 2
      • Use a spudger to pry up and disconnect the smaller screen cable press connector.
      Ask FixBot
    17. Surface Pro 7+ Screen Removal: step 22, image 1 of 3 Surface Pro 7+ Screen Removal: step 22, image 2 of 3 Surface Pro 7+ Screen Removal: step 22, image 3 of 3
      • Use a spudger to pry up and disconnect the wide screen cable press connector, starting on one of the short sides and moving to the other.
      Ask FixBot
    18. Surface Pro 7+ Screen Removal, Remove the screen: step 23, image 1 of 1
      • Remove the screen.
      Ask FixBot
Finish Line
Spencer Day
210,419 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 14
All Time: 96
