Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide will show you how to remove the power switch connected to the motherboard. Steps can be followed in reverse to install a new power switch.
  1. Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  2. Carefully flip the unit back over. Locate the seam. Lift and separate the upper half of the case from the lower half of the case. Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
    • Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
  5. The power switch is connected to the motherboard near the top left of the console. Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
    • The power switch is connected to the motherboard near the top left of the console.
    • Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
    • Do not detach the connector by pulling on the wires. This could damage the wires or the socket.
Cameron Deines
610 Reputation
2 Guides authored
Cal Poly, Team 4-47, Amido Fall 2010 Member of Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Members
15 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 77
All Time: 19,101
