Super Nintendo Power Switch Replacement
  1. Super Nintendo Power Switch Replacement, Outer Case: step 1, image 1 of 1
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  2. Super Nintendo Power Switch Replacement: step 2, image 1 of 3 Super Nintendo Power Switch Replacement: step 2, image 2 of 3 Super Nintendo Power Switch Replacement: step 2, image 3 of 3
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. Super Nintendo Power Switch Replacement, Power Switch: step 3, image 1 of 1
    • Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
  4. Super Nintendo Power Switch Replacement: step 4, image 1 of 2 Super Nintendo Power Switch Replacement: step 4, image 2 of 2
    • The power switch is connected to the motherboard near the top left of the console.
    • Remove the connector from the motherboard using your fingers. You may need to "wiggle" it out by using a rocking motion.
    • Do not under any circumstances detach or attempt to detach the connector by pulling on the wires as this could damage the socket/wire connection.
Cameron Deines
700 Reputation
2 Guides authored
Cal Poly, Team 4-47, Amido Fall 2010 Member of Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Members
25 Guides authored
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 75
All Time: 23,481
