Summer LookOut Duo Battery Replacement
    1. Summer LookOut Duo Battery Replacement, Battery: step 1, image 1 of 3 Summer LookOut Duo Battery Replacement, Battery: step 1, image 2 of 3 Summer LookOut Duo Battery Replacement, Battery: step 1, image 3 of 3
      • Flip the device over so the back is facing up.
      • Remove the 9 mm screw using a Phillips #1 screwdriver.
      • Lift the battery panel away from the device.
      Ask FixBot
    2. Summer LookOut Duo Battery Replacement: step 2, image 1 of 3 Summer LookOut Duo Battery Replacement: step 2, image 2 of 3 Summer LookOut Duo Battery Replacement: step 2, image 3 of 3
      • Flip the handheld monitor over and let the battery fall out into your hand.
      • Using angled tweezers, gently remove the plastic wire coupling from the side of the open battery compartment.
      • If the coupling struggles to release, with a loose but firm grip, slightly wiggle the plastic wire coupling back and forth until it releases.
      • Remove the battery from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 19
All Time: 206
