Introduction
Use this guide to replace the front wheels on your Summer Infant 3D Lite stroller.
Locate the black plastic tabs on the front wheel. There should be two, opposite sides from each other.
Firmly press both tabs inwards, and use your other hand to pull the wheel off
How can i orther the front wheels
Hi, you can contact the Summer Infant Consumer Relations Team by calling 800-268-6237, Monday-Thursday, 8:00am-6:00pm EST and Friday 8am-3pm EST
It is really to press the two tabs, and pull at the same time???
Any help plz will be appreciated.
Is not easy to to all that, these tabs are very hard
We have the arrow pointing the down but now we can’t get the front wheel off. It’s stuck and we can’t seem to push both tabs down. This feels impossible!
If you use an adjustable wrench, it’s easy to push in the tabs. Set the opening just slightly larger than the diameter of the round piece and push in.
Just as the other customer said once you put it on wrong. The front wheel it is impossible to get off. I caught a hand cramp trying to pull that industrial strength locking system. Plzzzz help its crooked.
Use an adjustable wrench - set it slightly larger than the round part and push against both tabs at the same time.
We used two metal spoons to press the buttons while pulling wheel off. It worked.. Lol..
I’m trying to return this stroller and now I know the reason they make these wheels so impossible to remove. so I can’t return! My fingers feel like they are bleeding. I’ve tried pliers, a wrench, & scissors, and nothing pushes the tabs in enough for me to pull the wheel off (and my wheels are on correctly). This is another reason why more expensive strollers are soooooo worth it!! One simple button and the wheels come off my uppababy :)
7 other people completed this guide.
15 Comments
How can i order the front wheels
Hi, you can contact the Summer Infant Consumer Relations Team by calling 800-268-6237, Monday-Thursday, 8:00am-6:00pm EST and Friday 8am-3pm EST.
I think there should be a video tutorial for this product. thank you!!
Yes i think there should be a video
The Front wheel is less bending in the axis, how to make straight by hand
How do I do this if I put the wheels in the wrong way? I can see the tabs but I can’t grip enough of it.
I have the same issue. One wheel has the arrow down. I cant seem to get the wheel off.. please help
copied from a very helpful FB post I found after installing the wheel upside down: “I also did the same thing the little black tabs are near the break lever you use the break leaver with one of the black tabs to hold it down and then I used my flat head screw driver to push the other tab down... Only then was I able to pop the front wheel off because you have to pinch both black tabs at the same time to get it off. Hope this helps and good luck!”
Is there a video for this
No video but if you follow my instructions you should get it off.
Ok so it isnt as easy at first, once you see what you need to click, it will come right off. If you look at step 1 you will see what tab you need to press. That same clip is also on the opposite side of the the example. You definitely need 2 flat head screwdrivers to get it off. It's no way to get it off with just your fingers. So you need one flat head to push in the 1st tab, then turn the stroller over and use the 2nd flat head to push in the 2nd tab. The wheel should slide off. Good luck. Hope it helps
What to do if a front wheel is wobbling as we stroll..?
Not sure what happened to cause this but the metal bar in the middle of wheel looks bent and making wheel wobble.
This is impossible
Where can I just order the front wheel? The metal piece that goes in between the two wheels is bent and it will not roll right.
joanna28146 - Reply
Stroller Guy -
Puse las ruedas al reves y ahora no puedo sacarlas para ponerlas correcto ,que puedo hacer Ayuda
Isabel Mtz - Reply
Me pasó lo mismo, coloqué las ruedas al revés y hice lo que dice aquí, busque los 2 que me mantiene la rueda dentro los empuje con la llave de casa y logre retirarla
penelope Medina Rosa -
I wish it was easy! My tabs will not push it, we have tried everything.
Bojones - Reply
I put the front wheel o wrong..how can i get it off.. Its upside down?
Alicia Cox - Reply
Did you get it off?
Ron Hossannah -
