Introduction
Use this guide to replace the right thumbstick on your Steam Deck LCD. The stick is part of a complete module and needs to be replaced as one unit. Although nearly identical, the procedure for the left thumbstick can be found here.
Remember: follow general electrostatic discharge (ESD) safety procedures while repairing your device.
Replacement thumbsticks require calibration to work as expected. Read about how to do that here.
Note: Each Steam Deck ships with one of two different models of thumbsticks, Type A or Type B. Although nearly identical, capacitive touch capability relies on the correct type to be installed. To identify which replacement thumbsticks you need, navigate to Settings → System and check the Steam Deck Controller ID: if the Controller ID starts with “MEDA” that device uses Type A thumbsticks; if the Controller ID starts with “MHDA” that device uses Type B thumbsticks.
Video Overview
Power down your Steam Deck and unplug any cables.
Tool used on this step:FixMat$36.95
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
Use a Phillips driver to remove the three screws securing the board shield:
One 3.4 mm screw
Two 3.7 mm screws
Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
Use a pair of tweezers to slide the cable out of its connector.
Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
Remove the right thumbstick.
To identify which replacement thumbsticks you need, navigate to Settings → System and check the Steam Deck Controller ID.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
23 other people completed this guide.
5 Guide Comments
Does this apply to the OLED model as well?
The OLED model's right thumbstick guide can be found here.
Type A right joystick has been out of stock for a while, is it coming back soon?
We're working to get more in stock — check back soon!
