Introduction
Prerequisiti per sostituire il pulsante Home nell'iPhone 5s.
Da notare che solo il pulsante originale del telefono può sfruttare la funzione Touch ID. Installare un nuovo pulsante Home può solo garantire le funzioni di base del pulsante, non le funzionalità Touch ID.
Rimuovere la singola vite prigioniera Philips #000 tenendo facendo attenzione al cavo del pulsante Home.
Per riassemblare il telefono, seguire le istruzioni in ordine inverso.
35 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
6 Comments
Unfortunately this will never work, the sensor is paired to the logic board. If you want to replace the defective tactile switch, remove all the plastic/rubber parts on the flex cable and resolder a new switch or disassemble the switch and clean/replace the metal dome switch. If you want to repair fingerprint function, just give up.
I purchased a full iphone 5S home button replacement assembly (comes with the home button attached to the flex cable) And now the fingerprint function does not show up at all. Where it's supposed to show in settings as "Touch ID and Passcode" It only says passcode. Restored as new to 7.1, still doing the same thing.. Anybody have ideas?
Only the home button that came with the phone has Touch ID function. In order to replace it and still have Touch ID, you would need to get it replaced at an Apple Store.
p3rs0nn -
I think you can easily break the Touch ID sensor
