Introduction
This video shows how to replace and reassemble Sony Xperia Z5 LCD display.
Video Overview
Heat the back cover to soften the adhesive sticker.
Place the suction cup and insert metal opening tool to open a gap from top side.
Insert the guitar pick and slide it to cut the adhesive sticker underneath.
Remove back cover.
Release battery connector.
Pull off the adhesive tape underneath the battery.
Pry up battery.
Release rear camera connector, front camera connector, audio jack connector and main flex connector on the motherboard.
Twist off screws there.
Remove that rubber securing bracket.
Loosen side button contactors ( Attention: the fingerprint sensor is here, be careful to loosen it), then remove the whole main flex assembly.
Release LCD screen flex connector, charging port connector, microphone connector here.
Remove motherboard.
The sticker underneath is strong, so use heat gun to soften it for a few minutes.
Remove LCD screen carefully.
