Sony Xperia Z5 LCD Screen Replacement
Video Overview
  1. Sony Xperia Z5 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
    • Remove SIM card tray.
  2. Sony Xperia Z5 LCD Screen Replacement: step 2, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement: step 2, image 2 of 2
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and insert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 LCD Screen Replacement: step 3, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 3, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 3, image 3 of 3
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  4. Sony Xperia Z5 LCD Screen Replacement: step 4, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 4, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 4, image 3 of 3
    • Release battery connector.
    • Pull off the adhesive tape underneath the battery.
    • Pry up battery.
  5. Sony Xperia Z5 LCD Screen Replacement: step 5, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 5, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 5, image 3 of 3
    • Release rear camera connector, front camera connector, audio jack connector and main flex connector on the motherboard.
    • Twist off screws there.
    • Remove that rubber securing bracket.
  6. Sony Xperia Z5 LCD Screen Replacement: step 6, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 6, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 6, image 3 of 3
    • Remove metal cover and twist off two screws.
    • Loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 LCD Screen Replacement: step 7, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 7, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 7, image 3 of 3
    • Loosen side button contactors ( Attention: the fingerprint sensor is here, be careful to loosen it), then remove the whole main flex assembly.
  8. Sony Xperia Z5 LCD Screen Replacement: step 8, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 8, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 8, image 3 of 3
    • Remove rear camera.
    • Remove that securing bracket, then remove front camera.
  9. Sony Xperia Z5 LCD Screen Replacement: step 9, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 9, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 9, image 3 of 3
    • Release LCD screen flex connector, charging port connector, microphone connector here.
    • Remove motherboard.
  10. Sony Xperia Z5 LCD Screen Replacement: step 10, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement: step 10, image 2 of 2
    • Remove charging port flex.
  11. Sony Xperia Z5 LCD Screen Replacement: step 11, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement: step 11, image 2 of 2
    • Remove microphone.
  12. Sony Xperia Z5 LCD Screen Replacement: step 12, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement: step 12, image 2 of 2
    • Remove the metal bracket covering on the LCD screen flex.
  13. Sony Xperia Z5 LCD Screen Replacement: step 13, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 13, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 13, image 3 of 3
    • The sticker underneath is strong, so use heat gun to soften it for a few minutes.
    • Remove LCD screen carefully.
    • Take extra care when prying along the bottom edge of the display to avoid damaging the display cable.
  14. Sony Xperia Z5 LCD Screen Replacement: step 14, image 1 of 1
    • Done.
Lenka
2,376 Reputation
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 82
All Time: 97,547
