Introduction
Use this guide to remove the rear-facing camera in your Sony Xperia Z3 Compact.
Place a suction cup on the back cover and pull to open a gap.
Insert a guitar pick into the gap and slide it around the corner of the back cover to cut the adhesive sticker.
Finally, remove the back cover.
Be careful, the back cover is fragile and can break.
It can be a good idea to wear protective glasses. If the glass shatters, it could enter your eye.
Disconnect the NFC antenna.
Unscrew the screws holding the black midframe in place.
Remove midframe.
Disconnect the battery (orange connector on the bottom left of your phone; top left corner in the image)
Remove rear camera bracket.
