Sony Xperia Z3 Compact Rear Camera Replacement
  1. Sony Xperia Z3 Compact Rear Camera Replacement, Heat the cover glue: step 1, image 1 of 1
    • Heat up along the edges of the cover to soften the glue.
    • Ideal temperature is around 120 - 150 °C for 60 seconds.
  2. Sony Xperia Z3 Compact Rear Camera Replacement: step 2, image 1 of 1
    • Place a suction cup on the back cover and pull to open a gap.
    • Insert a guitar pick into the gap and slide it around the corner of the back cover to cut the adhesive sticker.
  3. Sony Xperia Z3 Compact Rear Camera Replacement: step 3, image 1 of 1
    • Finally, remove the back cover.
    • Be careful, the back cover is fragile and can break.
    • It can be a good idea to wear protective glasses. If the glass shatters, it could enter your eye.
  4. Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: step 4, image 1 of 3 Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: step 4, image 2 of 3 Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: step 4, image 3 of 3
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove midframe.
  5. Sony Xperia Z3 Compact Rear Camera Replacement: step 5, image 1 of 2 Sony Xperia Z3 Compact Rear Camera Replacement: step 5, image 2 of 2
    • Disconnect the battery (orange connector on the bottom left of your phone; top left corner in the image)
    • Remove rear camera bracket.
  6. Sony Xperia Z3 Compact Rear Camera Replacement: step 6, image 1 of 3 Sony Xperia Z3 Compact Rear Camera Replacement: step 6, image 2 of 3 Sony Xperia Z3 Compact Rear Camera Replacement: step 6, image 3 of 3
    • components on the mainboard are fragile, be careful in the next step.
    • disconnect the flat top cable with a spudger
Sophia
43,810 Reputation
62 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 15,853
