Sony Xperia Z3 Compact Front Camera Replacement
  1. Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: step 1, image 1 of 3 Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: step 1, image 2 of 3 Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: step 1, image 3 of 3
    • Carefully use a heat gun or hairdryer to melt the adhesive holding the rear case to the phone.
    • Use a suction cup to lift the rear case slightly, enough to slide an opening pick around the edge and loosen the adhesive.
    • Remove back cover.
  2. Sony Xperia Z3 Compact Front Camera Replacement: step 2, image 1 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 2, image 2 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 2, image 3 of 3
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove back frame.
  3. Sony Xperia Z3 Compact Front Camera Replacement: step 3, image 1 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 3, image 2 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 3, image 3 of 3
    • Remove front camera.
  4. Sony Xperia Z3 Compact Front Camera Replacement: step 4, image 1 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 4, image 2 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 4, image 3 of 3
    • Remove bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  5. Sony Xperia Z3 Compact Front Camera Replacement: step 5, image 1 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 5, image 2 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 5, image 3 of 3
    • Release connectors and screw.
  6. Sony Xperia Z3 Compact Front Camera Replacement: step 6, image 1 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 6, image 2 of 3 Sony Xperia Z3 Compact Front Camera Replacement: step 6, image 3 of 3
    • Remove motherboard.
  7. Sony Xperia Z3 Compact Front Camera Replacement: step 7, image 1 of 1
    • Disconnect the battery flex cable.
Sophia
43,810 Reputation
62 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 10
All Time: 6,963
