Sony Xperia Z1 Compact Battery Replacement
  1. Sony Xperia Z1 Compact Battery Replacement, Back Cover: step 1, image 1 of 1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Battery Replacement: step 2, image 1 of 1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Battery Replacement: step 3, image 1 of 2 Sony Xperia Z1 Compact Battery Replacement: step 3, image 2 of 2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Battery Replacement, Battery: step 4, image 1 of 2 Sony Xperia Z1 Compact Battery Replacement, Battery: step 4, image 2 of 2
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Battery Replacement: step 5, image 1 of 2 Sony Xperia Z1 Compact Battery Replacement: step 5, image 2 of 2
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
  6. Sony Xperia Z1 Compact Battery Replacement: step 6, image 1 of 1
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Battery Replacement: step 7, image 1 of 1
    • Remove the battery from the device
kinan badr
386 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 38
All Time: 11,487
