Introduction
The Battery of the phone can become worn with continued use. This guide will show you how to remove the Battery of Sony Xperia Z1 Compact.
Attach the small suction cup to the back cover near the bottom of the phone.
Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
